[GRASS-QA] GRASS QA: martinl | ./grass6/ps/ps.map/do_labels.c |no clones | 1 monsters | 0 warnings
Mon Jan 8 05:49:34 EST 2007
Hello martinl,
ANALYSIS
ps/ps.map/do_labels.c functions
do_labels (Begins at: 27 Ends at: 90)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
do_label (Begins at: 93 Ends at: 346)
Complexity:   |      45 |   *** | MONSTER |
CalledNBR:    |      58 |     * |         |
LOC:          |     254 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
