[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.net.alloc/main.c |no clones | 2 monsters | 0 warnings
Mon Jan 8 13:44:34 EST 2007
Hello jachym,
ANALYSIS
vector/v.net.alloc/main.c functions
main (Begins at: 35 Ends at: 323)
Complexity:   |      24 |     * |         |
CalledNBR:    |     101 |   *** | MONSTER |
LOC:          |     289 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
