Hello jachym,
ANALYSIS
vector/v.lrs/v.lrs.where/main.c functions
main (Begins at: 35 Ends at: 197)
Complexity: | 14 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 58 | * | |
LOC: | 163 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
