[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.net.path/path.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Jan 8 15:45:58 EST 2007
Hello jachym,
ANALYSIS
vector/v.net.path/path.c functions
path (Begins at: 24 Ends at: 288)
Complexity: | 28 | ** | Warning |
ParamNBR: | 5 | * | |
CalledNBR: | 104 | *** | MONSTER |
LOC: | 265 | *** | MONSTER |
1 metric are OUT OF RANGE!
cmp (Begins at: 290 Ends at: 298)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
