[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.in.dxf/write_vect.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Jan 10 15:56:27 EST 2007
Hello jachym,
ANALYSIS
vector/v.in.dxf/write_vect.c functions
write_vect (Begins at: 14 Ends at: 71)
Complexity: | 6 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 30 | | OK |
LOC: | 58 | | OK |
metrics are OK
write_done (Begins at: 73 Ends at: 117)
ParamNBR: | 1 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 45 | | OK |
metrics are OK
get_field_cat (Begins at: 119 Ends at: 219)
Complexity: | 15 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 101 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
