[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.in.dxf/read_dxf.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Jan 10 17:40:57 EST 2007
Hello martinl,
ANALYSIS
vector/v.in.dxf/read_dxf.c functions
dxf_open (Begins at: 8 Ends at: 36)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 29 | | OK |
metrics are OK
dxf_close (Begins at: 38 Ends at: 45)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
dxf_find_header (Begins at: 48 Ends at: 59)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 12 | | OK |
metrics are OK
dxf_read_code (Begins at: 65 Ends at: 80)
ParamNBR: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
dxf_fgets (Begins at: 82 Ends at: 93)
Complexity: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
big_percent (Begins at: 98 Ends at: 117)
LOC: | 20 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
