[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.overlay/line_area.c
|no clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Jan 14 07:51:15 EST 2007
Hello jachym,
ANALYSIS
vector/v.overlay/line_area.c functions
point_area (Begins at: 20 Ends at: 45)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 7 | | OK |
LOC: | 26 | | OK |
metrics are OK
line_area (Begins at: 47 Ends at: 224)
Complexity: | 21 | * | |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 49 | * | |
LOC: | 178 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
