[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.out.ogr/main.c |no
clones | 3 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Jan 14 08:41:32 EST 2007
Hello jachym,
ANALYSIS
vector/v.out.ogr/main.c functions
main (Begins at: 40 Ends at: 550)
Complexity: | 60 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 209 | *** | MONSTER |
LOC: | 511 | *** | MONSTER |
3 metric are OUT OF RANGE!
mk_att (Begins at: 553 Ends at: 631)
Complexity: | 12 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 33 | | OK |
LOC: | 79 | | OK |
at least 1 values are close to an outlier please consider revising code
OGR_list_write_drivers (Begins at: 635 Ends at: 661)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
