[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.surf.idw/main.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Jan 14 09:36:37 EST 2007
Hello jachym,
ANALYSIS
vector/v.surf.idw/main.c functions
main (Begins at: 50 Ends at: 380)
Complexity: | 27 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 70 | ** | Warning |
LOC: | 331 | *** | MONSTER |
1 metric are OUT OF RANGE!
newpoint (Begins at: 382 Ends at: 413)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 32 | | OK |
metrics are OK
calculate_distances (Begins at: 415 Ends at: 469)
Complexity: | 6 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 0 | | OK |
LOC: | 55 | | OK |
metrics are OK
calculate_distances_noindex (Begins at: 471 Ends at: 513)
Complexity: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
