[GRASS-QA] GRASS QA: robertoa | ./grass6/vector/lidar/lidarlib/raster.c |no clones | 2 monsters | 0 warnings
Mon Jan 15 19:57:24 EST 2007
Hello robertoa,
ANALYSIS
vector/lidar/lidarlib/raster.c functions
P_Sparse_Points (Begins at: 15 Ends at: 174)
Complexity:   |      19 |     * |         |
ParamNBR:     |      18 |   *** | MONSTER |
CalledNBR:    |      70 |    ** | Warning |
LOC:          |     160 |     * |         |
1 metric are OUT OF RANGE!
P_Regular_Points (Begins at: 179 Ends at: 269)
Complexity:   |      11 |       |      OK |
ParamNBR:     |      14 |   *** | MONSTER |
CalledNBR:    |       7 |       |      OK |
LOC:          |      91 |       |      OK |
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
