[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.perturb/normalsv.c |no clones | 0 monsters | 0 warnings
Tue Jan 16 11:45:42 EST 2007
Hello markus,
ANALYSIS
vector/v.perturb/normalsv.c functions
normalsv (Begins at: 14 Ends at: 40)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-16 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
