[GRASS-QA] GRASS QA: jachym | ./grass6/display/d.mon/pgms/which.c
	|no clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sun Jan 28 07:09:10 EST 2007
Hello jachym,
ANALYSIS
display/d.mon/pgms/which.c functions
main (Begins at: 9 Ends at: 19)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
