[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/do_scalebar.c |no
	clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Tue Jan 30 03:41:49 EST 2007
Hello hamish,
ANALYSIS
ps/ps.map/do_scalebar.c functions
do_scalebar (Begins at: 20 Ends at: 176)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      48 |     * |         |
LOC:          |     157 |     * |         |
metrics are OK
nice_number (Begins at: 179 Ends at: 193)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-30 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
