[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.what.rast/main.c
|no clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Jan 31 13:52:00 EST 2007
Hello markus,
ANALYSIS
vector/v.what.rast/main.c functions
main (Begins at: 40 Ends at: 339)
Complexity: | 33 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 110 | *** | MONSTER |
LOC: | 300 | *** | MONSTER |
2 metric are OUT OF RANGE!
by_row (Begins at: 342 Ends at: 346)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 5 | | OK |
metrics are OK
by_cat (Begins at: 349 Ends at: 353)
LOC: | 5 | | OK |
metrics are OK
srch_cat (Begins at: 356 Ends at: 364)
Complexity: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-31 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
