[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.topidx/file_io.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Jul 6 05:03:42 EDT 2007
Hello martinl,
ANALYSIS
raster/r.topidx/file_io.c functions
getcells (Begins at: 8 Ends at: 74)
Complexity: | 13 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 31 | | OK |
LOC: | 67 | | OK |
metrics are OK
putcells (Begins at: 78 Ends at: 99)
Complexity: | 2 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 22 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
