[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.kappa/prt_mat.c |1
clones ( prt_mat.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Jul 6 06:19:25 EDT 2007
Hello martinl,
ANALYSIS
raster/r.kappa/prt_mat.c functions
prn_error_mat (Begins at: 12 Ends at: 175)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 39 | * | |
LOC: | 164 | * | |
metrics are OK
collapse (Begins at: 179 Ends at: 196)
Complexity: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 18 | | OK |
metrics are OK
longcomp (Begins at: 199 Ends at: 205)
Complexity: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
longcomp
In raster/r.kappa/prt_mat.c clones of longcomp are:
lib/driver/Polygon.c cmp_int
Threshold GRASS6 key metrics values at 2007-07-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
