[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.li/r.li.patchnum/main.c |1 clones ( main.c )| 0 monsters | 0 warnings
Fri Jul 6 07:08:42 EDT 2007
Hello carlos,
ANALYSIS
raster/r.li/r.li.patchnum/main.c functions
main (Begins at: 24 Ends at: 52)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
patch_number (Begins at: 54 Ends at: 173)
Complexity:   |      22 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |     120 |     * |         |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  main
In raster/r.li/r.li.patchnum/main.c clones of  main are:
	raster/r.li/r.li.richness/richness.c  main
	raster/r.li/r.li.dominance/dominance.c  main
	raster/r.li/r.li.simpson/simpson.c  main
	raster/r.li/r.li.shannon/shannon.c  main
Threshold GRASS6 key metrics values at 2007-07-06 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
