[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.contour/main.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Jul 6 07:47:42 EDT 2007
Hello carlos,
ANALYSIS
raster/r.contour/main.c functions
main (Begins at: 52 Ends at: 223)
Complexity: | 12 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 78 | ** | Warning |
LOC: | 172 | * | |
at least 1 values are close to an outlier please consider revising code
get_z_array (Begins at: 226 Ends at: 243)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 18 | | OK |
metrics are OK
getlevels (Begins at: 247 Ends at: 343)
Complexity: | 9 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 22 | | OK |
LOC: | 97 | | OK |
metrics are OK
displaceMatrix (Begins at: 351 Ends at: 374)
Complexity: | 2 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 3 | | OK |
LOC: | 24 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
