[GRASS-QA] GRASS QA: carlos | ./grass6/lib/gpde/N_solvers.c |2 clones ( N_solvers.c )| 0 monsters | 0 warnings
Fri Jul 6 08:41:04 EDT 2007
Hello carlos,
ANALYSIS
lib/gpde/N_solvers.c functions
N_solver_gauss (Begins at: 46 Ends at: 81)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
N_solver_lu (Begins at: 83 Ends at: 151)
CalledNBR:    |      14 |       |      OK |
LOC:          |      69 |       |      OK |
metrics are OK
N_solver_cholesky (Begins at: 153 Ends at: 197)
Complexity:   |       5 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
gauss_elimination (Begins at: 199 Ends at: 229)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
lu_decomposition (Begins at: 231 Ends at: 261)
LOC:          |      31 |       |      OK |
metrics are OK
cholesky_decomposition (Begins at: 263 Ends at: 326)
CalledNBR:    |       2 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
backward_solving (Begins at: 328 Ends at: 358)
ParamNBR:     |       4 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
forward_solving (Begins at: 360 Ends at: 374)
LOC:          |      15 |       |      OK |
metrics are OK
thomalg (Begins at: 380 Ends at: 422)
CalledNBR:    |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
vectmem (Begins at: 424 Ends at: 430)
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  gauss_seidel  jacobi
In lib/gpde/N_solvers_classic_iter.c clones of  gauss_seidel are:
	lib/gpde/N_solvers_classic_iter.c  jacobi
In lib/gpde/N_solvers_classic_iter.c clones of  jacobi are:
	lib/gpde/N_solvers_classic_iter.c  gauss_seidel
Threshold GRASS6 key metrics values at 2007-07-06 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
