[GRASS-QA] GRASS QA: carlos | ./grass6/display/d.rast.num/number.c
|no clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Jul 11 08:04:36 EDT 2007
Hello carlos,
ANALYSIS
display/d.rast.num/number.c functions
main (Begins at: 53 Ends at: 315)
Complexity: | 21 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 93 | *** | MONSTER |
LOC: | 263 | ** | Warning |
1 metric are OUT OF RANGE!
draw_number (Begins at: 319 Ends at: 367)
Complexity: | 5 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 49 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
