[GRASS-QA] GRASS QA: carlos |
./grass6/raster/r.univar2/r.univar_main.c |1 clones (
r.univar_main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Jul 11 08:41:50 EDT 2007
Hello carlos,
ANALYSIS
raster/r.univar2/r.univar_main.c functions
set_params (Begins at: 26 Ends at: 48)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 23 | | OK |
metrics are OK
main (Begins at: 54 Ends at: 207)
Complexity: | 23 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 35 | | OK |
LOC: | 154 | * | |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
set_params
In raster/r.univar2/r.univar_main.c clones of set_params are:
raster/r.univar2/r3.univar_main.c set_params
Threshold GRASS6 key metrics values at 2007-07-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
