[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.surf.rst/main.c |1
clones ( r.univar_main.c main.c )| 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Jul 11 08:41:50 EDT 2007
Hello carlos,
ANALYSIS
vector/v.surf.rst/main.c functions
main (Begins at: 128 Ends at: 790)
Complexity: | 92 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 280 | *** | MONSTER |
LOC: | 663 | *** | MONSTER |
3 metric are OUT OF RANGE!
print_tree (Begins at: 794 Ends at: 832)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 39 | | OK |
metrics are OK
clean_fatal_error (Begins at: 836 Ends at: 863)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 28 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
clean_fatal_error
In vector/v.surf.rst/main.c clones of clean_fatal_error are:
raster/r.resamp.rst/main.c clean_fatal_error
Threshold GRASS6 key metrics values at 2007-07-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
