[GRASS-QA] GRASS QA: glynn | ./grass6/lib/init/set_data.c |no
clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Jul 12 07:21:31 EDT 2007
Hello glynn,
ANALYSIS
lib/init/set_data.c functions
main (Begins at: 53 Ends at: 272)
Complexity: | 27 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 87 | *** | MONSTER |
LOC: | 220 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
list_locations (Begins at: 275 Ends at: 282)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 8 | | OK |
metrics are OK
list_mapsets (Begins at: 285 Ends at: 326)
Complexity: | 7 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 42 | | OK |
metrics are OK
first_word (Begins at: 329 Ends at: 338)
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
hit_return (Begins at: 341 Ends at: 349)
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
