[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/gisinit.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Jul 12 07:21:31 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/gisinit.c functions
G_gisinit (Begins at: 39 Ends at: 76)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 38 | | OK |
metrics are OK
G_no_gisinit (Begins at: 78 Ends at: 96)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 19 | | OK |
metrics are OK
G__check_gisinit (Begins at: 98 Ends at: 104)
CalledNBR: | 4 | | OK |
LOC: | 7 | | OK |
metrics are OK
gisinit (Begins at: 107 Ends at: 137)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
