[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.to.vect/areas.c |4 clones ( areas.c )| 0 monsters | 0 warnings
Thu Jul 12 13:38:42 EDT 2007
Hello carlos,
ANALYSIS
raster/r.to.vect/areas.c functions
extract_areas (Begins at: 108 Ends at: 151)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
update_list (Begins at: 159 Ends at: 319)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |     161 |     * |         |
metrics are OK
end_vline (Begins at: 324 Ends at: 332)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
end_hline (Begins at: 334 Ends at: 342)
LOC:          |       9 |       |      OK |
metrics are OK
start_vline (Begins at: 347 Ends at: 359)
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
start_hline (Begins at: 361 Ends at: 373)
LOC:          |      13 |       |      OK |
metrics are OK
get_ptr (Begins at: 377 Ends at: 414)
LOC:          |      38 |       |      OK |
metrics are OK
nabors (Begins at: 416 Ends at: 482)
CalledNBR:    |       4 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
read_next (Begins at: 486 Ends at: 495)
LOC:          |      10 |       |      OK |
metrics are OK
alloc_areas_bufs (Begins at: 500 Ends at: 525)
CalledNBR:    |       5 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
equiv_areas (Begins at: 530 Ends at: 597)
CalledNBR:    |       7 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
map_area (Begins at: 599 Ends at: 628)
LOC:          |      30 |       |      OK |
metrics are OK
add_to_list (Begins at: 632 Ends at: 665)
Complexity:   |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
assign_area (Begins at: 670 Ends at: 683)
Complexity:   |       2 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
more_areas (Begins at: 687 Ends at: 702)
LOC:          |      16 |       |      OK |
metrics are OK
more_equivs (Begins at: 706 Ends at: 721)
LOC:          |      16 |       |      OK |
metrics are OK
update_width (Begins at: 724 Ends at: 751)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  more_equivs  more_areas  start_hline  start_vline
In raster/r.to.vect/areas.c clones of  start_vline are:
	raster/r.to.vect/areas.c  start_hline
In raster/r.to.vect/areas.c clones of  more_areas are:
	raster/r.to.vect/areas.c  more_equivs
In raster/r.to.vect/areas.c clones of  more_equivs are:
	raster/r.to.vect/areas.c  more_areas
In raster/r.to.vect/areas.c clones of  start_hline are:
	raster/r.to.vect/areas.c  start_vline
Threshold GRASS6 key metrics values at 2007-07-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
