[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.bilinear/main.c |no clones | 0 monsters | 2 warnings
Sun Jul 15 04:39:56 EDT 2007
Hello markus,
ANALYSIS
raster/r.bilinear/main.c functions
main (Begins at: 24 Ends at: 260)
Complexity:   |      19 |     * |         |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     237 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
