[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.statistics/o_adev.c |no clones | 0 monsters | 0 warnings
Sun Jul 15 09:09:18 EDT 2007
Hello markus,
ANALYSIS
raster/r.statistics/o_adev.c functions
o_adev (Begins at: 16 Ends at: 95)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
a_dev (Begins at: 98 Ends at: 124)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
