[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.proj.seg/readcell.c |no clones | 0 monsters | 0 warnings
Mon Jul 16 12:34:42 EDT 2007
Hello martinl,
ANALYSIS
raster/r.proj.seg/readcell.c functions
readcell (Begins at: 16 Ends at: 109)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |      94 |       |      OK |
metrics are OK
get_block (Begins at: 111 Ends at: 134)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
