[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.info/main.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Jul 16 15:45:19 EDT 2007
Hello carlos,
ANALYSIS
raster/r.info/main.c functions
main (Begins at: 37 Ends at: 391)
Complexity: | 42 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 144 | *** | MONSTER |
LOC: | 355 | *** | MONSTER |
3 metric are OUT OF RANGE!
format_double (Begins at: 395 Ends at: 399)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
compose_line (Begins at: 402 Ends at: 417)
Complexity: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 16 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
