[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.surf.area/main.c |no clones | 0 monsters | 0 warnings
Mon Jul 16 15:45:20 EDT 2007
Hello carlos,
ANALYSIS
raster/r.surf.area/main.c functions
main (Begins at: 75 Ends at: 178)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      38 |     * |         |
LOC:          |     104 |       |      OK |
metrics are OK
add_row_area (Begins at: 183 Ends at: 264)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      12 |       |      OK |
LOC:          |      82 |       |      OK |
metrics are OK
add_null_area (Begins at: 269 Ends at: 278)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
v3cross (Begins at: 283 Ends at: 289)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
v3mag (Begins at: 294 Ends at: 298)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
