[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.resamp.stats/main.c
	|1 clones ( main.c )| 0 monsters | 1 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Mon Jul 16 15:45:20 EDT 2007
Hello carlos,
ANALYSIS
raster/r.resamp.stats/main.c functions
build_method_list (Begins at: 43 Ends at: 60)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
find_method (Begins at: 62 Ends at: 71)
LOC:          |      10 |       |      OK |
metrics are OK
resamp_unweighted (Begins at: 81 Ends at: 153)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      73 |       |      OK |
metrics are OK
resamp_weighted (Begins at: 155 Ends at: 244)
CalledNBR:    |      20 |       |      OK |
LOC:          |      90 |       |      OK |
metrics are OK
main (Begins at: 246 Ends at: 385)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      68 |    ** | Warning |
LOC:          |     140 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
  build_method_list
In raster/r.resamp.stats/main.c clones of  build_method_list are:
	raster/r.series/main.c  build_method_list
Threshold GRASS6 key metrics values at 2007-07-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
