[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.clean/prune.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Jul 18 06:23:40 EDT 2007
Hello martinl,
ANALYSIS
vector/v.clean/prune.c functions
prune (Begins at: 35 Ends at: 213)
Complexity: | 29 | ** | Warning |
ParamNBR: | 4 | | OK |
CalledNBR: | 71 | ** | Warning |
LOC: | 179 | * | |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
