[GRASS-QA] GRASS QA: carlos | ./grass6/raster3d/r3.to.rast/main.c
|no clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Jul 20 18:47:02 EDT 2007
Hello carlos,
ANALYSIS
raster3d/r3.to.rast/main.c functions
fatal_error (Begins at: 48 Ends at: 66)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 19 | | OK |
metrics are OK
set_params (Begins at: 71 Ends at: 97)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 27 | | OK |
metrics are OK
g3d_to_raster (Begins at: 102 Ends at: 172)
Complexity: | 12 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 71 | | OK |
metrics are OK
open_output_map (Begins at: 177 Ends at: 186)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
close_output_map (Begins at: 191 Ends at: 195)
ParamNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
main (Begins at: 200 Ends at: 394)
Complexity: | 22 | * | |
CalledNBR: | 76 | ** | Warning |
LOC: | 195 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
