[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.to.rast3elev/main.c
|1 clones ( main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Jul 20 18:47:04 EDT 2007
Hello carlos,
ANALYSIS
raster/r.to.rast3elev/main.c functions
get_raster_value_as_double (Begins at: 64 Ends at: 94)
Complexity: | 7 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
check_input_maps (Begins at: 99 Ends at: 146)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 48 | | OK |
metrics are OK
open_input_raster_map (Begins at: 151 Ends at: 164)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 14 | | OK |
metrics are OK
close_input_raster_map (Begins at: 169 Ends at: 173)
LOC: | 5 | | OK |
metrics are OK
fatal_error (Begins at: 178 Ends at: 195)
Complexity: | 5 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 18 | | OK |
metrics are OK
set_params (Begins at: 200 Ends at: 236)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 37 | | OK |
metrics are OK
elev_raster_to_g3d (Begins at: 241 Ends at: 373)
Complexity: | 22 | * | |
CalledNBR: | 31 | | OK |
LOC: | 133 | * | |
metrics are OK
main (Begins at: 378 Ends at: 552)
Complexity: | 18 | * | |
CalledNBR: | 56 | * | |
LOC: | 175 | * | |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.to.rast3elev/main.c clones of get_raster_value_as_double are:
raster3d/r3.out.vtk/writeVTKData.c get_raster_value_as_double
raster/r.out.vtk/writeascii.c get_raster_value_as_double
Threshold GRASS6 key metrics values at 2007-07-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
