[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.kernel/main.c |no clones | 2 monsters | 2 warnings
Fri Jul 20 19:04:07 EDT 2007
Hello carlos,
ANALYSIS
vector/v.kernel/main.c functions
L (Begins at: 36 Ends at: 59)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
main (Begins at: 62 Ends at: 408)
Complexity:   |      30 |    ** | Warning |
CalledNBR:    |     135 |   *** | MONSTER |
LOC:          |     347 |   *** | MONSTER |
2 metric are OUT OF RANGE!
read_points (Begins at: 412 Ends at: 441)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
compute_all_distances (Begins at: 446 Ends at: 470)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
compute_all_net_distances (Begins at: 475 Ends at: 542)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      17 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
compute_net_distance (Begins at: 546 Ends at: 593)
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      10 |       |      OK |
LOC:          |      48 |       |      OK |
at least 1 values are close to an outlier please consider revising code
compute_distance (Begins at: 595 Ends at: 641)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       8 |       |      OK |
LOC:          |      47 |       |      OK |
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
