[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.to.rast3/main.c |1 clones ( main.c main.c )| 0 monsters | 0 warnings
Fri Jul 20 19:04:07 EDT 2007
Hello carlos,
ANALYSIS
raster/r.to.rast3/main.c functions
fatal_error (Begins at: 49 Ends at: 68)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
set_params (Begins at: 73 Ends at: 84)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
raster_to_g3d (Begins at: 91 Ends at: 162)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
main (Begins at: 168 Ends at: 340)
Complexity:   |      22 |     * |         |
CalledNBR:    |      53 |     * |         |
LOC:          |     173 |     * |         |
metrics are OK
open_input_raster_map (Begins at: 347 Ends at: 362)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
close_input_raster_map (Begins at: 367 Ends at: 371)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.to.rast3/main.c clones of  open_input_raster_map are:
	raster3d/r3.out.vtk/main.c  open_input_map
Threshold GRASS6 key metrics values at 2007-07-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
