[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.clump/main.c |no clones | 0 monsters | 0 warnings
Fri Jul 20 19:04:06 EDT 2007
Hello carlos,
ANALYSIS
raster/r.clump/main.c functions
main (Begins at: 26 Ends at: 123)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      45 |     * |         |
LOC:          |      98 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
