[GRASS-QA] GRASS QA: markus | ./grass6/lib/vector/Vlib/build.c |2 clones ( build.c )| 0 monsters | 0 warnings
Tue Jul 24 08:05:36 EDT 2007
Hello markus,
ANALYSIS
lib/vector/Vlib/build.c functions
prnmsg (Begins at: 43 Ends at: 63)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Vect_build (Begins at: 66 Ends at: 76)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Vect_get_built (Begins at: 79 Ends at: 116)
CalledNBR:    |       0 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Vect_build_partial (Begins at: 119 Ends at: 226)
Complexity:   |      18 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      46 |     * |         |
LOC:          |     108 |       |      OK |
metrics are OK
Vect_save_topo (Begins at: 235 Ends at: 274)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
Vect_topo_dump (Begins at: 277 Ends at: 366)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      90 |       |      OK |
metrics are OK
Vect_save_spatial_index (Begins at: 375 Ends at: 414)
LOC:          |      40 |       |      OK |
metrics are OK
Vect_spatial_index_dump (Begins at: 417 Ends at: 428)
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  Vect_save_spatial_index  Vect_save_topo
In lib/vector/Vlib/build.c clones of  Vect_save_topo are:
	lib/vector/Vlib/build.c  Vect_save_spatial_index
In lib/vector/Vlib/build.c clones of  Vect_save_spatial_index are:
	lib/vector/Vlib/build.c  Vect_save_topo
Threshold GRASS6 key metrics values at 2007-07-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
