[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.net/main.c |no clones | 0 monsters | 1 warnings
Tue Jul 24 09:01:23 EDT 2007
Hello martinl,
ANALYSIS
vector/v.net/main.c functions
main (Begins at: 27 Ends at: 206)
Complexity:   |      20 |     * |         |
CalledNBR:    |      78 |    ** | Warning |
LOC:          |     180 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
