[GRASS-QA] GRASS QA: markus | ./grass6/display/d.font/main.c |no clones | 0 monsters | 0 warnings
Thu Jul 26 17:38:53 EDT 2007
Hello markus,
ANALYSIS
display/d.font/main.c functions
main (Begins at: 33 Ends at: 109)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |      77 |       |      OK |
metrics are OK
read_freetype_fonts (Begins at: 111 Ends at: 135)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
print_font_list (Begins at: 137 Ends at: 146)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-26 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
