[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.colors/main.c |no
clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Jun 1 03:04:42 EDT 2007
Hello glynn,
ANALYSIS
raster/r.colors/main.c functions
scan_rules (Begins at: 35 Ends at: 49)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 15 | | OK |
metrics are OK
rules_list (Begins at: 51 Ends at: 77)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 27 | | OK |
metrics are OK
list_rules (Begins at: 79 Ends at: 85)
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
find_rule (Begins at: 87 Ends at: 96)
Complexity: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
main (Begins at: 98 Ends at: 360)
Complexity: | 42 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 108 | *** | MONSTER |
LOC: | 263 | ** | Warning |
2 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
