[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.surf.rst/main.c |1 clones ( main.c )| 3 monsters | 0 warnings
Fri Jun 1 05:37:56 EDT 2007
Hello markus,
ANALYSIS
vector/v.surf.rst/main.c functions
main (Begins at: 128 Ends at: 810)
Complexity:   |      92 |   *** | MONSTER |
CalledNBR:    |     280 |   *** | MONSTER |
LOC:          |     683 |   *** | MONSTER |
3 metric are OUT OF RANGE!
print_tree (Begins at: 814 Ends at: 852)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
clean_fatal_error (Begins at: 856 Ends at: 883)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  clean_fatal_error
In vector/v.surf.rst/main.c clones of  clean_fatal_error are:
	raster/r.resamp.rst/main.c  clean_fatal_error
Threshold GRASS6 key metrics values at 2007-06-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
