[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.vol.rst/user1.c |no
clones | 5 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Jun 1 08:49:54 EDT 2007
Hello markus,
ANALYSIS
vector/v.vol.rst/user1.c functions
INPUT (Begins at: 63 Ends at: 343)
Complexity: | 44 | *** | MONSTER |
ParamNBR: | 4 | | OK |
CalledNBR: | 71 | ** | Warning |
LOC: | 281 | *** | MONSTER |
2 metric are OUT OF RANGE!
OUTGR (Begins at: 350 Ends at: 736)
Complexity: | 53 | *** | MONSTER |
ParamNBR: | 0 | | OK |
CalledNBR: | 106 | *** | MONSTER |
LOC: | 387 | *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
