[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.maxlik/main.c |no clones | 0 monsters | 1 warnings
Fri Jun 1 23:58:20 EDT 2007
Hello hamish,
ANALYSIS
imagery/i.maxlik/main.c functions
main (Begins at: 28 Ends at: 186)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      75 |    ** | Warning |
LOC:          |     159 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
