[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/error.c |no clones | 0 monsters | 0 warnings
Sat Jun 2 03:20:07 EDT 2007
Hello hamish,
ANALYSIS
lib/gis/error.c functions
G_message (Begins at: 105 Ends at: 126)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_verbose_message (Begins at: 128 Ends at: 152)
LOC:          |      25 |       |      OK |
metrics are OK
G_important_message (Begins at: 154 Ends at: 186)
LOC:          |      33 |       |      OK |
metrics are OK
G_fatal_error (Begins at: 188 Ends at: 211)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_warning (Begins at: 213 Ends at: 234)
CalledNBR:    |       4 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_suppress_warnings (Begins at: 236 Ends at: 252)
CalledNBR:    |       0 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_sleep_on_error (Begins at: 254 Ends at: 272)
LOC:          |      19 |       |      OK |
metrics are OK
G_set_error_routine (Begins at: 274 Ends at: 288)
ParamNBR:     |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G_unset_error_routine (Begins at: 290 Ends at: 295)
LOC:          |       6 |       |      OK |
metrics are OK
print_error (Begins at: 298 Ends at: 349)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
log_error (Begins at: 351 Ends at: 386)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
write_error (Begins at: 389 Ends at: 421)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
mail_msg (Begins at: 424 Ends at: 442)
Complexity:   |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
print_word (Begins at: 445 Ends at: 496)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
print_sentence (Begins at: 499 Ends at: 548)
CalledNBR:    |      12 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
G_info_format (Begins at: 550 Ends at: 567)
CalledNBR:    |       3 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
