[GRASS-QA] GRASS QA: markus |
./grass6/imagery/i.smap/bouman/interp.c |no clones | 0
monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Jun 2 07:55:26 EDT 2007
Hello markus,
ANALYSIS
imagery/i.smap/bouman/interp.c functions
seq_MAP (Begins at: 22 Ends at: 43)
Complexity: | 2 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 4 | | OK |
LOC: | 22 | | OK |
metrics are OK
seq_MAP_routine (Begins at: 46 Ends at: 138)
Complexity: | 13 | | OK |
CalledNBR: | 35 | | OK |
LOC: | 93 | | OK |
metrics are OK
alpha_dec_max (Begins at: 140 Ends at: 159)
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 20 | | OK |
metrics are OK
print_N (Begins at: 161 Ends at: 176)
Complexity: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 16 | | OK |
metrics are OK
print_alpha (Begins at: 179 Ends at: 186)
CalledNBR: | 2 | | OK |
LOC: | 8 | | OK |
metrics are OK
interp (Begins at: 189 Ends at: 271)
Complexity: | 7 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 16 | | OK |
LOC: | 83 | | OK |
at least 1 values are close to an outlier please consider revising code
MLE (Begins at: 273 Ends at: 292)
ParamNBR: | 4 | | OK |
LOC: | 20 | | OK |
metrics are OK
up_char (Begins at: 295 Ends at: 345)
Complexity: | 9 | | OK |
ParamNBR: | 5 | * | |
LOC: | 51 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
