[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.univar2/stats.c |1 clones ( stats.c )| 0 monsters | 0 warnings
Sun Jun 3 19:22:08 EDT 2007
Hello markus,
ANALYSIS
raster/r.univar2/stats.c functions
create_univar_stat_struct (Begins at: 19 Ends at: 49)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
free_univar_stat_struct (Begins at: 55 Ends at: 67)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
print_stats (Begins at: 73 Ends at: 215)
Complexity:   |      19 |     * |         |
CalledNBR:    |      43 |     * |         |
LOC:          |     143 |     * |         |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.univar2/stats.c clones of  free_univar_stat_struct are:
	lib/sites/sites.c  G_site_free_struct
Threshold GRASS6 key metrics values at 2007-06-03 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
