[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_solvers.c |2
	clones ( N_geom.c N_gradient.c N_les_assemble.c N_les.c
	N_solvers.c )| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Tue Jun  5 18:19:18 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_solvers.c functions
N_solver_gauss (Begins at: 44 Ends at: 75)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
N_solver_lu (Begins at: 77 Ends at: 139)
CalledNBR:    |      14 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
gauss_elimination (Begins at: 141 Ends at: 169)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
lu_decomposition (Begins at: 171 Ends at: 202)
LOC:          |      32 |       |      OK |
metrics are OK
backward_solving (Begins at: 204 Ends at: 232)
ParamNBR:     |       4 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
forward_solving (Begins at: 234 Ends at: 248)
LOC:          |      15 |       |      OK |
metrics are OK
thomalg (Begins at: 254 Ends at: 296)
CalledNBR:    |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
vectmem (Begins at: 298 Ends at: 304)
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  gauss_seidel  jacobi
In lib/gpde/N_solvers_classic_iter.c clones of  jacobi are:
	lib/gpde/N_solvers_classic_iter.c  gauss_seidel
In lib/gpde/N_solvers_classic_iter.c clones of  gauss_seidel are:
	lib/gpde/N_solvers_classic_iter.c  jacobi
Threshold GRASS6 key metrics values at 2007-06-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
