[GRASS-QA] GRASS QA: carlos | ./grass6/lib/gpde/N_solvers_krylov.c |2 clones ( N_solvers_krylov.c )| 0 monsters | 0 warnings
Mon Jun 11 11:29:01 EDT 2007
Hello carlos,
ANALYSIS
lib/gpde/N_solvers_krylov.c functions
N_solver_pcg (Begins at: 63 Ends at: 240)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |     178 |     * |         |
metrics are OK
N_solver_cg (Begins at: 242 Ends at: 405)
CalledNBR:    |      29 |       |      OK |
LOC:          |     164 |     * |         |
metrics are OK
N_solver_bicgstab (Begins at: 407 Ends at: 566)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      35 |       |      OK |
LOC:          |     160 |     * |         |
metrics are OK
scalar_product (Begins at: 568 Ends at: 592)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
N_matrix_vector_product (Begins at: 594 Ends at: 620)
LOC:          |      27 |       |      OK |
metrics are OK
N_sparse_matrix_vector_product (Begins at: 622 Ends at: 650)
LOC:          |      29 |       |      OK |
metrics are OK
add_vectors_scalar2 (Begins at: 653 Ends at: 677)
ParamNBR:     |       6 |     * |         |
LOC:          |      25 |       |      OK |
metrics are OK
add_vectors_scalar (Begins at: 680 Ends at: 704)
ParamNBR:     |       5 |     * |         |
LOC:          |      25 |       |      OK |
metrics are OK
sub_vectors_scalar (Begins at: 707 Ends at: 730)
LOC:          |      24 |       |      OK |
metrics are OK
add_vectors (Begins at: 732 Ends at: 754)
LOC:          |      23 |       |      OK |
metrics are OK
sub_vectors (Begins at: 756 Ends at: 778)
LOC:          |      23 |       |      OK |
metrics are OK
scalar_vector_product (Begins at: 780 Ends at: 798)
LOC:          |      19 |       |      OK |
metrics are OK
sync_vectors (Begins at: 800 Ends at: 821)
LOC:          |      22 |       |      OK |
metrics are OK
check_symmetry (Begins at: 823 Ends at: 898)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      76 |       |      OK |
metrics are OK
N_create_diag_precond_matrix (Begins at: 900 Ends at: 930)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  sub_vectors  add_vectors
In lib/gpde/N_solvers_krylov.c clones of  add_vectors are:
	lib/gpde/N_solvers_krylov.c  sub_vectors
In lib/gpde/N_solvers_krylov.c clones of  sub_vectors are:
	lib/gpde/N_solvers_krylov.c  add_vectors
Threshold GRASS6 key metrics values at 2007-06-11 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
