[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.in.poly/get_item.c |no clones | 0 monsters | 1 warnings
Thu Jun 14 04:51:07 EDT 2007
Hello hamish,
ANALYSIS
raster/r.in.poly/get_item.c functions
get_item (Begins at: 2 Ends at: 101)
Complexity:   |      18 |     * |         |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      17 |       |      OK |
LOC:          |     100 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
